1991 Saab 9000 bad wobble feeling
73,215 MILES • 4 CYL • FWD • MANUAL
KROOP720
i just replaced the lower balljoint right side front on my 91 saab 9000s. After doing so i started driving and could here a wierd noise and felt a wobble on that side. The tire doesnt appear to be wobbling but something deffinetly is. Any ideas as to what might be wrong?
Jul 29, 2009 at 2:18 AM
  • 31,937 POSTS
Hi there,
make sure tat the ball joint is fitted into the lower control arm correctly and the nut is tight and secured with a split pin, check the tie rod end if you removed this, also wheel nuts and wheel bearings, start here.
mark (mhpautos)
Jul 29, 2009 at 11:00 PM
