Hi there,
make sure tat the ball joint is fitted into the lower control arm correctly and the nut is tight and secured with a split pin, check the tie rod end if you removed this, also wheel nuts and wheel bearings, start here.
Mark (mhpautos)
SPONSORED LINKS
Thursday, July 30th, 2009 AT 6:00 AM
