1997 Saab 900 What part has the spring for the ignition key
1997 SAAB 900
125,000 MILES • 4 CYL • FWD • MANUAL
EZBURNER
Hello, the spring that pushed the key to the "ON" position after starting is worn/broken and I want to know what is the part that has the spring for the ignition? Is the spring in the electrical part, the ignition switch? Or is the spring in the key cylinder? I am wanting to replace the part that has the spring to fix the problem but don't know which part to buy. thanks for the help.
Cheers
Aug 25, 2010 at 8:26 PM
MNTHNY4
  • 612 POSTS
the section with the spring is the cylinder section ,u can take the cyl out & stretch spring then refit to cyl & re-assembly after that ,try if that works for u ,if not u will need to order key cyl from dealer.
Aug 29, 2010 at 5:24 PM
