1997 Saab 900 Shuts off
AURORA
Engine Performance problem
1997 Saab 900 4 cyl Two Wheel Drive Automatic 123k miles
this car has 123k miles had for about a year and lately the car has been shutting off when I brake or when I make a Y turn,,could possibly need turn up or something?
Feb 13, 2009 at 10:05 AM
ALCER
Open the hood, look at the large diameter hose that comes from the turbo into a L shapa black hard plastic valve that the other end goes to the intake aluminum pipe into the injection system. That valve is called Turbo bypass valve 4441895 ($75 from dealer or free from Junk yard). This valve apparently gives a false signal to the computer about gasoline leak and it is programmed to shut the fuel system OFF.
Feb 13, 2009 at 12:15 PM
