1997 Saab 900 Dies while driving
V_ROCK
Engine Performance problem
1997 Saab 900 4 cyl Front Wheel Drive Automatic 135K miles
I have a 1997 Saab 900 that has developed a dangerous problem. It origionally was haed to start and sometimes didn't start at all/ Starting fluid was required. Now it has started to stop running while at expressway speeds or at stop signs. It just cuts out completely. No dash lights, nothing. Usually it will start right back up after shutting off the key and turning it to start. Does anyone have any ideas? Fuel pressure is fine, voltage seems fine. ECM/ECU maybe? Thanks for any help.
Sep 23, 2010 at 3:16 PM
MNTHNY4
  • 612 POSTS
u need a engine crank position sensor ,good luck.
Oct 6, 2010 at 7:53 AM
