1997 Saab 900 clutch cable replacement
1997 SAAB 900
17,000 MILES • 4 CYL • FWD • MANUAL
JERRYDALY
This is a self adjusting cable whcih I have connected to the pedal and instructions say to connect at the other end i should use a pry bar to force the clutch arm back so the cable will reach. The clutch arm does not want to move. Any advice on how the clutch arm shoud behave or how mcuh force I should be willing to use to move the arm?
Apr 20, 2008 at 2:12 AM
CAAZI
Don't pry against where the battery rests. Use a good pry bar and get it down to the strong metal directly below the arm. Good leverage makes all the difference. Your not going to break the arm... put some muscle into it! =)
Sep 26, 2008 at 4:57 AM
