Hi my car temperature guage is going into the red zone
Oct 10, 2008 at 8:12 AM
TRON2007
MEMBER
First you check the level of the antifreeze. Second if the level of antifreeze is good check thermostat or replace is near the water pump on the left side of the car.
After you replace the thermostat and the heat going up and is the water pump.
But first check those and replace.
