1996 Saab 900 smells like it is running rich fuel mixture
1996 SAAB 900
152,546 MILES • 4 CYL • FWD • MANUAL
SAAB 23
Hard to start. Seems like it is starving for fuel. Kicks over run for a few seconds and cuts off. Takes several times for it to start and idle. Once idleing have to let run before driving for a minute or two.
Can injection run rich? I just got the car replaced the coil and now this started. It started sputering going down the highway which caused the check engine light to come on. I just don't know what to check..
Any Help would be appreciated..
what can you spray the ignition switch to keep it from sticking??
Thanks in advance
Dec 3, 2009 at 10:33 AM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Dec 3, 2009 at 10:44 AM
