1996 Saab 900 Convertible top won't go up
50,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKE BOWERS
The convertible top on my 1996 SAAB 900 goes about half-way up and then gets stuck.
I can hear a clicking sound as though there are some teeth broken off of a gear.
Oct 13, 2008 at 8:31 AM
JNOVACK
  • 723 POSTS
does the top go up if you move it by hand if so I would check all the moving parts and mostly the motor the gear is proboly plastic and you need to replace it
Oct 13, 2008 at 10:03 AM
MIKE BOWERS
Thanks.
That sounds like it.
The top will go down if I manually lift the plastic cover that goes over the stored top. But the top will go up only half-way, stalls, and I cannot move it manually, although I can hear the electric motor running.
I know I can't fix this myself and have to take it to a dealer.
Am I looking at a $200 repair or a $2,000 repair?
Oct 13, 2008 at 11:28 AM
