1995 Saab 900 Convertable
HOTCAR95
1995 Saab 900 4 cyl Front Wheel Drive Automatic
Convertable cover grinds and you have to help pull it up so the top will come out, same thing on closing and the top will not lock down when closing warring light says to check soft top.
Jul 7, 2008 at 12:38 PM
SERVICE WRITER
  • 9,123 POSTS
I would start by accessing the pivot points on the frame of the top to check for worn parts or severe need of lubrication. I don't have an exploded view, but the dealer parts department may be able to supply that. Too much resistance is going to cause the mortor to burnout.
Not hearing the grinding makes it hard to say, but may have a problem in the motor already.
Jul 7, 2008 at 10:48 PM
