1995 Saab 900 A/C Help
1995 SAAB 900
10,400 MILES • 4 CYL • 2WD • AUTOMATIC
DWILLIS6
Blower is blowing hot air-It was rigged when I bought it with a jumper from the fuse box to the compressor. It has worked GREAT for 2 weeks (don't you know) but now is blowing hot.
Any sugggestions? Where do I start?
Jul 23, 2008 at 12:00 PM
MASTERTECHTIM
  • 4,750 POSTS
you eithe blew up the compressor or your out of freon. start by recharging system
Jul 23, 2008 at 12:03 PM
DWILLIS6
i put in freon still blows hot.
thank you for your response
Jul 23, 2008 at 1:05 PM
MASTERTECHTIM
  • 4,750 POSTS
heres the problem i have. with you hot wiring the system you could have damaged the compressor from running it out of freon. does the compressor come on still? do you have pressure gauges and what are the low side pressures and high side pressures and did you evacuate the system, put it on a vacuum and then recharge it with the correct amount of freon?
Jul 23, 2008 at 1:11 PM
