I am replacing the clutch and need to remove the axles. Do i remove the axles at the bearing flange, or do I seperate the CV joints?
Mar 3, 2009 at 12:54 AM
2CARPRO JACK
✓ASE Certified Mechanic
Unbolt and seperate the ball joints and remove the d/s by popping it out of the trans, the p/s you will need to remove the drive belt,bottom alt mounting bolt to access the bolts for the axle shaft bearing mount so you can remove that axle
Mar 3, 2009 at 7:45 AM
