1992 Saab 900 Do I need to replace my clutch? Ugh...
BO2L
Transmission problem
1992 Saab 900 4 cyl Front Wheel Drive Manual 190K miles
I went to get into my car today and I noticed a huge puddle under my car running from the front drivers side tire and under the driver side door... I went to get into it to start it up and when I put my foot on the clutch the peddle when right to the floor so I knen it was not good so I didnt attempt to start it or do anything... just got out and took my other car to work
May 4, 2010 at 12:43 PM
  • 31,937 POSTS
HI there,
You will have a failed master cyl, slave cyl or clutch hydraulic line, if it is a slave cylinder this will be a job for a SAAB work shop as there are some special tools required, for now,add some clutch fluid (brake fluid) and see if you can locate the leak first.
mark (mhpautos)
May 4, 2010 at 7:20 PM
