Check the belt tension and or replace the belts. These often squeal because when you first start the car there is a heavier than normal load on the alternator which causes belt slippage.
[quote:7600429c4b="delano4545"]Noises problem
1992 Saab 900 4 cyl Front Wheel Drive Manual 171000 miles
belts squeel when starting up car when i come to a light and push the cluch in sqeeels until i take off again[/quote:7600429c4b]
Mar 17, 2009 at 9:58 AM
