Belts squeel when starting up car when I come to a light and push the cluch in sqeeels until I take off again
Tuesday, March 17th, 2009 AT 4:42 PM
BOGONE
MEMBER
Check the belt tension and or replace the belts. These often squeal because when you first start the car there is a heavier than normal load on the alternator which causes belt slippage.
