1991 Saab 900 Resurfaced Head
1991 SAAB 900
1DAD1
Engine Mechanical problem
1991 Saab 900 4 cyl Two Wheel Drive Manual
I have a 1991 Saab 900S turbo 16 valve, (H type engine). I blew the head gasket
and warped the head. I took the head and had it resurfaced and was told by the
machinist that to resurface the head would require them removing .018 inch which
he then told me that would be to much and that it would be better replacing the
head. Doing this would effect the valves opening and closing properly. At this
time I did not understand what the man meant. Before blowing the gasket the car
ran fine. After blowing the head gasket, I found it increasingly hard to start, so
I decided to replace the head gasket by myself.
Up to this time I never had a vehicle blow a head gasket. I am on a limited fixed
income, so I decided to resurce the cylinder head nonetheless. I proceeded to
refit the head and completed getting the car back together. As I tried to start
the car, assuming it would start up with ease, I found myself having difficulty
starting the car once again and as the car started it made a loud knocking noise
coming from the valve region so I turned the car off immediately and am now
seeking advice.
The repair manual states that I should measure the clearence of the cam to the
tappet. If the camshaft exceeds a specified gap/tappet clearence, adjustment is
neceesary and theat I must record the values of each cam lobe compare the
differences and remove the tappets and shims from the valves keeping them
identified, measure the thickness of the existing shims compare them with the
correct clearences and determine the thickness of the new shims.
I believe that this is where my problem lies with respect to the loud knocking
heard as I started the engine. As I tried starting the engine I noticed the car
was repeating the same conditions I experienced when I had first blew the head
gasket. Since I replaced the head gasket, I was told, by a an associate, that I am
experiencing difficulty starting the engine due to the valves needing to be
adjusted with the correct shims and that I am losing compression in my cylinders
due to the valves not closing completely, which in turn is making it hard to
start.
I have not measured the clearences from the cam to tappets in the vehicle, but I
assume that this must be the reason for the loud knocking I heard and the
difficulty in starting the car.
My question to you is....if I get another cylinder head one that is not warped or
been resurfaced, will this solve my problem and get me mobile again? My family
needs a running vehicle, and I cannot at this time purchase another. Please reply!
Oct 13, 2009 at 12:02 AM
RACEFAN966
  • 5,029 POSTS
Ok I don't think that is the case. I think the clearence for the valves are now to close. So you are hearing the valves hitting the pistons. When you shave that much off a head you need to buy a head shim as well as the head gasket to put the head back to factory spec. These tolorances are very close on these engines. According to the specs more the 12 thousands removed a head shim is recomended. So I would pull the spark plugs and use a flashlight to look at the pistons to see if there is any marks on the tops if so then you should remove the head inspect the valve for and bent ones. Then get a new head gasket and a 15 thousands head shim. If you do need to get a shim make sure to gasket shalak (indian head) and coat the shim with it. Let me know what you find on the pistons.
Oct 13, 2009 at 3:16 AM
