2005 Saab 9-5 Trunk Wont Open
38,000 MILES • 6 CYL • AWD • AUTOMATIC
IRISHSHANNON
My remote key and the interior side panel door button will not pop the trunk. there is no noise associated with pushing the buttom and the key remote opens and locks car door ( trunk button does not work).
Feb 15, 2009 at 11:59 PM
IMPALASS
  • 3,112 POSTS
Hello
To better assist you please tell me your model 9-5. Is it a Aero, Arc or Linear? Also the engine size in liter.
Also, please go to Auto Zone (AZ) or O'Reilly's (OR) and for FREE they can pull the codes to the car. Most important: Once they check your codes, if they find something and you don't get it fixed and need to get back with us, please make sure you tell us exactly what the code was, number and all. Example, if the code was E0568 O2 Sensor bad. Then make sure you give us all of that. While there for FREE also they can bring their tester out and check your battery and alternator.
Feb 16, 2009 at 2:06 AM
DEREKOLIVEIRA
  • 23 POSTS
Hello!
The problem is broken wires ,left side near shock absorver s trunk!
Mar 22, 2009 at 6:47 AM
IMPALASS
  • 3,112 POSTS
Hello
Sorry so long to get back with you. I had some technical difficulties.
Great so you have figured it out and have it fixed?
Mar 23, 2009 at 3:40 PM
IMPALASS
  • 3,112 POSTS
Hello By the way, it looks like you may have some recalls on your vehicle. The dealer may fix these for free. Please contact the dealer service department, give them the VIN number of your car and have them check on these to see if they apply to you.
https://images.2carpros.com/forum/automotive_pictures/248015_Recalls_20.jpg
Mar 24, 2009 at 2:53 PM
