2004 Saab 9-5 Passenger Door won't work
KASPERJ
Electrical problem
2004 Saab 9-5 4 cyl Automatic 114000 miles
Hello! My Saab's passenger side door lock and window quit when I try and use the key faub and the window lever. The initial diagnosis was that it needs a new fuse in that door. The repairs on a Saab are really expensive. Can I buy a tool to take the door off and replace the fuse myself? Or is there a easier, cheaper way to do it?
Jul 20, 2010 at 7:55 AM
MNTHNY4
  • 612 POSTS
WHAT! ,do not know of a fuse in the door per say ,the fuses r in the fuse panel at the side of the dash on the driver side of vehicle if it is a LHD ,if u check fuses and they r good ,then u may have a bad twice control module this is located under the drivers seat [LHD] check if carpet is wet under seat sometimes the a/c drain becomes blocked & cause this to happen ,good luck .
Jul 23, 2010 at 6:07 AM
