2003 Saab 9-5 Leak cant find
90,000 MILES • 6 CYL • FWD • AUTOMATIC
CMYBOY
With the hood open looking at the firewall at the back of the engine I can see a drip. The location on the firewall where the drip is coming from is just right of center attached to the firewall . No fluid is getting into the driver compartment. Using a small mirror I tried to identify where the leak is coming from but cant find anything.
It kind of looks like its coming from a small canister about the size of a smokeless tobacco can?
Any ideas?
Thanks,
Ted
Sep 18, 2009 at 6:16 AM
MNTHNY4
  • 612 POSTS
u need a heater bypass valve ,valve can be had alone with out hoses ,cheaper .
Sep 28, 2009 at 3:36 PM
CMYBOY
[quote:9e9c88d03a="mnthny4"]u need a heater bypass valve ,valve can be had alone with out hoses ,cheaper .[/quote:9e9c88d03a]
Thanks you are correct got it fixed yesterday!
Thanks for the reply!
Sep 29, 2009 at 1:06 AM
MNTHNY4
  • 612 POSTS
hey u r most welcome ,ask a question anytime ,cool .
Sep 29, 2009 at 7:32 AM
CMYBOY
2003 SAAB 95 when driving the temp gauge works than for no reason drops off like if the car were turned off?
If you shut down the car and restart it work fine?
Any ideas?
Nov 19, 2009 at 1:50 AM
MNTHNY4
  • 612 POSTS
replace your coolant temp sensor ,by the way is ur check eng light on ,if so u may have a p0116 code related to faulty coolant thermostat ,which u will need to replace both thermostat & coolant temp sensor ,to correct cooling system fault issues .
Nov 19, 2009 at 4:30 AM
