2003 Saab 9-5 fuel pump
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
FIREFLY2003
how would i change a fuel pump in a 2003 SAAB 95?
Jul 27, 2009 at 5:00 AM
MNTHNY4
  • 612 POSTS
lift up rear seat lower cushion section & remove fuel pump cover ,then unplug fuel pressure feed line & return line ,but be carefull line ends are easy to break , twist ends left to right then pull up slowly to remove ,after that unscrew pump lock & pull out pump a little tricky to take out ,good luck .
Aug 29, 2009 at 2:09 PM
