2003 Saab 9-5 check engine light
70,000 MILES • 4 CYL • FWD • AUTOMATIC
RMDEWSNAP
I just, about 1000 miles ago, had to have my turbo replaced and since my check engine light goes on and off intermittently. More on than off. I replaced the plugs and air filter. After that it was off for a while but has come back on.
Any ideas or suggestions where to go from here? O2 sensor. In my readings I noticed there may be a front and rear sensor also. Is that the case.
Also the ligh comes on at when I start the car. Never when driving and it doesn't go off until I start the car again.
I have checked to make sure the gas cap is on tightly.
I appreciate the help!
May 16, 2010 at 1:50 AM
  • 75,988 POSTS
Hi rmdewsnap, Welcome to 2carpros and TY for the doantion
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
May 16, 2010 at 7:39 PM
RMDEWSNAP
The codes are 1334 and 1312. Any idea what I need to do about that?
May 22, 2010 at 12:54 AM
  • 75,988 POSTS
These are misfires code, could be the wrong type spark plugs or the direct ignition coil
May 22, 2010 at 4:39 AM
RMDEWSNAP
Found some discussions on some other sites and they stated could be caused by poor fuel deliver or low octane fuel. I changed the fuel filter, put in some very good injector cleaner and some octane booster and it's running like a champ. I think the real culprit was the fuel filter. From the look of it, it was never replaced in 70k miles. I bout the car used a year or so ago.
Thanks.
May 23, 2010 at 1:57 AM
