2003 Saab 9-5 auto trans issue
115,000 MILES • 4 CYL • FWD • AUTOMATIC
BOGER1776
My auto trans has been shifting hard for a while, but tonight when i went to check the fluid, trans fluid shot out of the filler tube. Even when i shut the car off it was still pressurized and would flow out. What could possibly cause this condition?
Sep 21, 2009 at 2:38 PM
MNTHNY4
  • 612 POSTS
possibly transmission internal mounted pump faulty ,causing no fluid flow through torque converter ,check trans codes ,codes will be set in system ,u will need a replacement trans & perform repairs to said transmission ,cheaper to replace with good used one .
Sep 30, 2009 at 7:14 AM
