2002 Saab 9-5 LEAKING MOTOR OIL
2002 SAAB 9-5
NOVADODGE7095
2002 Saab 9-5 4 cyl Two Wheel Drive Automatic
LEAKING MOTOR OIL ON SIDE OF STARTER.
Jun 9, 2008 at 9:23 AM
MNTHNY4
  • 612 POSTS
replace oil pressure sensor behind starter also look up on intake manifold if oily replace upper throttle housing seal clean area perform road test & recheck ,if oil leak is also coming from eng drive belt side between cyl head & block u will need to replace head gasket & update crankcase ventilation kit & hoses
Jun 11, 2008 at 2:36 PM
