2002 Saab 9-5 Im overheating
LARRYTHEFILMGUY
Engine Cooling problem
2002 Saab 9-5 6 cyl Front Wheel Drive Automatic
I had a few lines go out but still overheating. I am thinking it could be the thermostat but cant find the thing... where is it?
Jan 10, 2010 at 9:06 AM
MNTHNY4
  • 612 POSTS
your thermostat is located in the middle of the engine ,u have to remove intake manifold ,injector planum ,u also most remove upper rad hose tube which is pushed into thermostat housing ,this tube is sort of tricky to refit ,i mean the holding bolt at front ,good luck.
Jan 10, 2010 at 11:05 PM
