Front end clunking. Changed the ball joints, better but still have some clunking over bumps. Shocks?, tie rod ends?
Jan 27, 2010 at 3:36 AM
MNTHNY4
✓Experienced Mechanic
check your stabilizer bar end links & your front control arm rear mounted bushings ,check for rubber cracking or torn ,also make sure all your subframe bolts r tight ,good luck.
Jan 28, 2010 at 12:43 AM
