2002 Saab 9-5 AC vibration
105,000 MILES • 4 CYL • FWD • AUTOMATIC
MMRISIN
The airconditioning appears to work just fine. However, there is a vibration (expansion tube?) under the hood, when I turn the engine off, after running the AC. Can I just live with this without damaging the AC system? Also, can I put some sort of runner ring around this tube to prevent it from hitting against other parts under the hood, thus dampening the vibration?
Jul 30, 2010 at 5:40 AM
  • 75,988 POSTS
You can cushion it -have the compressor checked out could be the cause of the vibration.
Jul 30, 2010 at 8:41 PM
