2001 Saab 9-5 Water Leak
101,454 MILES • 6 CYL • FWD • AUTOMATIC
LEALABITUA
I have a small water leak I think is coming from the throtle body. Anyone else with the same problem?
What is recommended.
Oct 26, 2009 at 6:59 PM
MNTHNY4
  • 612 POSTS
check your heater bypass valve ,located to the back of engine tie straped to wire harness on firewall ,it is a black valve with hoses connected to it ,valve can be had alone cheaper ,if it is coming from throttle body there r only 2 water hoses connected to it ,but the only thing that leak in that area for a 9-5 is the heater bypass valve ,check that and get back to us ,if this info helped tell us thank that will let us know that u looked back .
Oct 27, 2009 at 12:21 AM
