2001 Saab 9-5 Thrust washer
2001 SAAB 9-5
JCDKEL
  • 7 POSTS
2001 Saab 9-5 4 cyl 128000 miles
replacing main thrust washer on saab 9-5, can get one on, but not the other... bought parts from dealer... any suggestions??
Jan 13, 2010 at 6:07 AM
MNTHNY4
  • 612 POSTS
remove all main bearing caps & crankshaft pulley from front ,this will give u movement in crank to allow u to fit both bearings ,make sure u fit them correctly ,if not engine will not turn ,good luck ,make sure u use lock tight on all nuts & bolts for conrod caps & main bearing caps when refitting them .
Jan 14, 2010 at 5:33 AM
