2001 Saab 9-5 Throttle return spring too low force
2001 SAAB 9-5
97,613 MILES • 4 CYL • AWD • AUTOMATIC
BRADLEY A BATES
How can I increase the force? The P1260 code is present on my tester taken from the OBS computer.
Dignostic Trouble Code information states: "Throttle Return Spring Too Low Force"
Dec 14, 2009 at 2:57 AM
MNTHNY4
  • 612 POSTS
sorry to say no spring repairs possibly ,what u have is your throttle body unit going bad ,the next stage will be p1231 or p1230 code been set ,which only repair is to replace unit ,this stage is what is call unit been in [LIMP HOME MODE] when that happens u first have to clear codes then replace throttle body unit ,start looking for a throttle body unit ,price from dealer $568.80 ,or check goldwingsaab.com ,good luck
Dec 15, 2009 at 4:07 AM
BRADLEY A BATES
is there ny chance of re-building the existing throttle body unit ?
Dec 16, 2009 at 1:00 AM
MNTHNY4
  • 612 POSTS
non that i know of off hand ,try using google search,u may get lucky & find somewhere that does .
Dec 16, 2009 at 5:55 AM
BRADLEY A BATES
"I bit the bullet" and purchased a new throttle unit at the SAAB dealer. two different mechanics told me that you spray something on it to clean it there is to many electric components and you will begin to get all kinds of DTC codes. They were right. New one works great@ $522.00 including new "O" rings from the dealer w/12 month warranty.
Dec 16, 2009 at 10:11 PM
