2001 Saab 9-5 code P1110
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
M88CAP
I get a dtc code of P1110 which is manufacturer fuel air metering.What is this and is it something I can fix myself?
Jun 29, 2009 at 8:41 AM
MNTHNY4
  • 612 POSTS
CHECK FOR VACUUM LEAK IN CHARGE AIR BYPASS VALVE ,valve located to the back mount to firewall ,should have a couple small vacuum type hoses plugs on to it ,one may have come loose ,or hose need replaicing.
Sep 29, 2009 at 8:17 AM
