2000 Saab 9-5 Power Steering Belt
OWEELOVER
Engine Cooling problem
2000 Saab 9-5 4 cyl Front Wheel Drive Automatic
The power steering belt keeps rubbing against the oil cooler. Could you tell me why this is happening??
Oct 20, 2009 at 1:11 AM
MNTHNY4
  • 612 POSTS
BELT not possible to rub against the oil cooler ,oil cooler is at front of vehicle ,it can only rub against eng timinc cover & the oil cooler lines running under the belt ,if so then the pipe section on the hose is bent upwards on belt ,check again .
Oct 20, 2009 at 2:12 AM
