2000 Saab 9-5 P0722 Code
2000 SAAB 9-5
DONESPENDINGMONEYONKID
Transmission problem
2000 Saab 9-5 4 cyl Automatic 175000 miles
I'm tired of dumping money into this car. Please help. My daughter was driving the car. She stopped at a signal then the car didn't want to go again...it justed revved like it was in neutral. She shut off the car then started it again...the car drove but the check engine light was on along with another light that looks like a sun with an ! in the middle. My neighbor hooked it up and got the P0722 code- he said it was a cheap part and that I could pick it up. I've been searching online and came up with a speedometer sensor that I found on eEuroparts. I have a friend that is a weekend garage mechanic who said he would help. I just want to make sure I'm buying the right part and also wondering where I can get a diagram that shows where and how this part goes in. Thank you for any help you can give me :)
Jun 4, 2010 at 3:59 PM
FACTORYJACK
  • 4,159 POSTS
Here is the best I could do. There are two sensors, and I believe they are identical parts, an input speed, and an output speed. To Remove
https://images.2carpros.com/forum/automotive_pictures/309872_97542611_1.gif
Lift up the main fuse box.
https://images.2carpros.com/forum/automotive_pictures/309872_97542612_2.gif
Clean the area round the sensor. Remove the retaining bolt and withdraw the sensor Unplug the sensor's connector. Fitting
https://images.2carpros.com/forum/automotive_pictures/309872_97542612_1.gif
[img] Plug in the sensor's connector. Fit the sensor in place and tighten the retaining bolt. Tightening torque: 6 Nm (4.5 ft. lbs.)
Refit the main fuse box.
Jun 4, 2010 at 5:30 PM
thank you!!!
Jun 4, 2010 at 6:11 PM
FACTORYJACK
  • 4,159 POSTS
Thank you!
Jun 5, 2010 at 4:36 AM
