2000 Saab 9-5 Machine oil smell/fumes
2000 SAAB 9-5
WBERMUDEZ
Smells problem
2000 Saab 9-5 4 cyl Front Wheel Drive Manual 103K miles
When I drive long distance (about 1.4hrs) even with windows open, there is a faint machine oil like odor that sticks to clothing; enough to have to change after every trip! Any ideas?
Sep 12, 2010 at 4:41 PM
MNTHNY4
  • 612 POSTS
check your crankcase ventilation system ,for cracked hoses & check valve ,also u may need to check your a/c recirculation motor function ,check if recirt door closes when u press button on control panel ,this door keeps outside air from coming in & also makes your a/c cooling much better.good luck.
Sep 20, 2010 at 12:00 AM
