2000 Saab 9-5 Leaking
123,465 MILES • 4 CYL • 2WD • AUTOMATIC
RAMS_28_81
Well I had just filled up my saab with premium gasoline at BP and i started smelling the gasoline all the way back home. When i got home i was going to work and found out that my car was leaking gasoline...... What do i do and where might it be leaking from.....
Oct 15, 2008 at 10:31 AM
  • 31,937 POSTS
Hi there,
i would be checking around the fuel injectors and filter, check if you can not see a leak , you may have to get the car up on a hoist to inspect the under body fuel lines & tank for a problem.
Mark (mhpautos)
Oct 15, 2008 at 11:52 AM
