2000 Saab 9-5 help........
11,800 MILES • 4 CYL • FWD • AUTOMATIC
THECALDER2
Two days ago my blinkers, wipers, and windows stopped working. The fuses are all fine. What do i do to fix this?
Nov 10, 2009 at 6:49 AM
MNTHNY4
  • 612 POSTS
first thing first let's do a electrical test locate fuse for one of the components that is inop ,remove fuse now turn ignition on take a test light and check if power is on one side of where u pull fuse ,if not move to next inop component do the same ,if no power then your problem is with the body control module [or dice unit as saab call it ]located under dash at d/s above relay box while there check if u see any burn wiring u may have a shorted wiring problem if it is not the control unit ,but all these inop component r controled through DICE UNIT .good luck
Nov 11, 2009 at 12:19 AM
