2000 Saab 9-5 FUSES FOR DIRECTIONAL SIGNAL
127,000 MILES • 4 CYL • FWD • AUTOMATIC
AWESLOC
THE 7.5 AMP FUSE FOR THE DIRECTIONAL SIGNAL KEEPS BLOWING AS SOON AS I REPLACE IT. THE TURN SIGNALS DO NOT WORK. WHAT CAN CAUSE THIS? DO I NEED TO CHECK THE BULBS IN THE FRONT AND REAR TO MAKE SURE THEY ARE IN PROPERLY OR IS IT A MORE LIKELY BIGGER PROBLEM?
Dec 2, 2009 at 11:34 PM
BUDDYCRAIGG
  • 2,262 POSTS
you've got bigger problems.
You will have to do a visual inspection of the wires, Looking for a wire that is shorted to ground.
Dec 3, 2009 at 4:56 PM
