2000 Saab 9-5 fuel filter location
88,000 MILES • 4 CYL • FWD • AUTOMATIC
CMCKEE
can you please tell me where the fuel filter is located. Also, my car will not start! I have changed out the spark plugs and had this car checked out at a dealership and they said it could be a case of bad gas or that the spark plugs need to be replaced and that having the recalled part replaced could correct this problem but it did not help.
I look forward to someone getting back to me as soon as possible.
May 3, 2009 at 10:51 AM
DAVE H
  • 13,383 POSTS
Check you are getting spark and fuel at spark plugs (cylinders)
FUEL FILTER
WARNING:Replacing fuel filter involves partial disassembly of fuel system. Work only in a well-ventilated area and use vapor extraction equipment if available. Keep a BE-rated fire extinguisher handy in case of fire. Wear protective gloves and goggles. DO NOT smoke anywhere near open fuel system.
Release fuel pressure. See FUEL SYSTEM PRESSURE RELEASE . Locate fuel filter at right front side of fuel tank. Remove fuel filter splash guard. Remove both banjo bolts at inlet and outlet fuel lines on filter. Remove fuel filter clamp bolt and filter. To install, reverse removal procedure. Tighten banjo bolts to specification. See TORQUE SPECIFICATIONS .
May 3, 2009 at 1:51 PM
