2000 Saab 9-5
MDRAKE
2000 Saab 9-5 Automatic 157000 miles
My primary question involves LED lights on dash/console which do not all work. How would I determine whether the lights might tell me of any current problems? Any other concerns of this model?
Nov 16, 2009 at 7:50 AM
MNTHNY4
  • 612 POSTS
get your sid display replaced ,that unit tells u of lights out ,low coolant ,low eng oil level ,alarm system malfunction ,other concern are if u just bought the vehicle ,& u dont have repair history ,then i would recommend replacing ,just as preventive maintenance components like ,coolant thermostat & coolant sensor ,if coolant sensor if blue then that is the original sensor ,next replace crankshaft position sensor ,check ur eng drive belt & pulleys ,if noisy replace any pulleys & tensioner that r ,those r just the main components that get most replaced on this vehicle.
Nov 18, 2009 at 11:06 PM
MDRAKE
Nov 19, 2009 at 1:37 AM
MNTHNY4
  • 612 POSTS
u r welcome ,& gook luck
Nov 19, 2009 at 4:33 AM
