1999 Saab 9-5 White Smoke
MULENANNY
Engine Performance problem
1999 Saab 9-5 4 cyl Two Wheel Drive Manual
I have white smoke coming out of my exhaust. I changed the head gasket and that is all good.I was told it is my turbo. Could this be the problem?
Apr 20, 2009 at 8:07 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated I would start by having a compression test done on the cylinders to double check the headgasket is good ...if this checks out OK, then it is possible the turbo has gone ... you generally get a lingering blue/white smoke when the turbo has gone ... with a headgasket it's a white dampish dissapearing smoke !! hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_550.png
Apr 20, 2009 at 8:53 PM
