1999 Saab 9-5 No left high beam - chgd bulb & ckd fuses
130,000 MILES • 4 CYL • FWD • MANUAL
SCOTTISHLASS
SID registers "FRONT LIGHT FAILURE" when the high beams are activated. The bulb has been replaced. All light fuses are still intact, including fuse #10 (high beam headlight left) under the hood. Even when the bulb is replaced by a known-working bulb, it still doesn't light. Suggestions?
Sep 2, 2009 at 6:03 AM
MNTHNY4
  • 612 POSTS
u need a headlamp control relay ,big orange relay in engine bay fuse box ,shake it side to side inplace then check light or just leave on high beam while doing that ,may come back on for a while then go back out ,anyway u need a relay.
Sep 29, 2009 at 8:06 AM
