1999 Saab 9-5 no clutch pressure
JAYD
Transmission problem
1999 Saab 9-5 4 cyl Front Wheel Drive Manual
I had to come to a sudden stop and I hit brakes but didn't take it out of gear right away. When I pressed the clutch, there was no pressure on it. I found some fluid around the driver wheel but saw no lines broken. The car sat for about 2 yrs before this happened. Could this be the clutch master cyl. or what could it be?
Nov 4, 2008 at 5:22 AM
DEREKOLIVEIRA
  • 23 POSTS
Check upper the pedal if you ca see same brake fluid?!follow the line to confirm!
Mar 22, 2009 at 11:31 AM
