1999 Saab 9-5 ITS COLD
202,000 MILES • 4 CYL • 2WD • AUTOMATIC
KASSMAN77
I am getting no heat from any of the vents on the drivers side!! There is heat everywhere else but there!! As well when the center vent is open it blows cool air out of it. Any suggestions?
Thank you
Jan 13, 2009 at 2:44 AM
KIWI06
  • 6 POSTS
You have a broken heater blend door. You can verify by pressing and releasing the climate control "Auto" and "Off" buttons simultaneously which will run the self-check. The computer display will show the number of faults on the left and the fault codes on the right. "08" indicates a broken left blend door ("11" for the right).
Hopefully, it's either the common "broken shaft" or "broken stop arm" issue, as there are fixes that are relatively inexpensive and not too difficult. (The Saab dealer will go with replacing the heater box - which is about 8 hours of labor and ends up being about $2000!) Do a web search for "Saab broken heater blend door," and you should find good pointers.
If you are not so lucky (I am not),it will be internal to the heater box or the shaft is broken right at the heater box. The only solution I know of is replacing the heater box. (Or you can stuff foam or rags or something in the driver's side heat path - that doesn't address the defrost, which still blows cold on the driver's side, but at least you don't end up with frost bite on your toes.)
Sep 10, 2009 at 2:17 AM
