1999 Saab 9-5 hose
GARY1973
Engine Mechanical problem
1999 Saab 9-5 4 cyl Front Wheel Drive Automatic
I have oil in the breather air hose, is this a bad pvc and if so can it be fixed with (c foam)?
Apr 25, 2010 at 1:49 AM
MNTHNY4
  • 612 POSTS
what is [ c foam] ,anyways u need to replace your crankcase ventilation conponents with the new updated version ,cost around $75 from dealer dont quote me on the price ,could be more ,note also that the kit does not come with all the hoses , also pull hose from valve cover & check if heavy white smoke comes out ,if so u may have some internal engine components worn ,good luck .
Jul 29, 2010 at 7:03 AM
