HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
SAAB
9-5
Climate Control
Heater
1999 SAAB 9-5 heater problem
J ISAACS
MEMBER
1999 SAAB 9-5
4 CYL
FWD
AUTOMATIC
90,000 MILES
I get heat on passenger side o heat on driver side
Sunday, January 6th, 2008 AT 4:14 PM
BLACKOP555
MECHANIC
Check your blend door located under the dash, in theair ducts, if one side is working and the other isnt a door is probably sticking or not moving.
SPONSORED LINKS
Sunday, January 6th, 2008 AT 6:42 PM
Please
login
or
register
to post a reply.
Related Heater Content
Heater
One Side Of My Heater Is Blow Cool Air, And The Other Side Is Blowing Warm Air When I Turn The Hearter On, On My Saad 95 Se
Asked by
ma504ac
1999
SAAB 9-5
GUIDE
Heater
Once the engine has been started and has run long enough to warm up the hot coolant is transferred into the heater core which is located inside the passenger compartment via...
2002 Saab 9-5 Heater Lamp
2002 Saab 9-5 4 Cyl Front Wheel Drive 106, 35 Miles The Lamp In The Heater-a/c Control On The Dash Has Gone Out, Is It A Hard Job To...
Asked by
tomcat58
1 ANSWER
2002
SAAB 9-5
1999 Saab 9-5 Heat Is Not Blowing On Driver Side...
I Have Dual Heating/ac System, On Driver Side Heat Is Not Working, Passenger Side Is Working Corectly, Ac Is Working On Both Side. This...
Asked by
petermarczak
1 ANSWER
1999
SAAB 9-5
Heating/cooling
Hvac Doesn't Work As It Should.I Can Feel Air Coming From Each Vent But Is The Same Temperature As The Ambient. When I'm Adjusting It From...
Asked by
Orlag
1999
SAAB 9-5
9-5 Saab
Heater Motor Runs Intermitently. I Have Heat But The Fan Seems To Run When It Wants To. Is This A Sign The Motor Is Going Out? Or Could This...
Asked by
Chuckobar
12 IMAGES
2002
SAAB 9-5
VIEW MORE
SPONSORED LINKS
Heater Not Working
Heater Not Working
Blend Door Actuator Replacement
Online car repair manuals
