1999 Saab 9-5 CHANGE SERPENTINE BELT
1999 SAAB 9-5
141,000 MILES • 4 CYL • 2WD • MANUAL
BC58MOS
HOW DO YOU CHANGE THE SERPENTINE BELT ON A 1999 SAAB 9-5 ?
Jan 27, 2010 at 11:21 PM
MNTHNY4
  • 612 POSTS
u will need to pry engine drive belt tensioner forward using a 1/2" type long socket extension then use a small nail to hold tensioner in forward position ,look for lock pin hole on tensioner ,then make sure to draw belt routing down on paper before u remove belt ,good luck.
Jan 28, 2010 at 12:40 AM
