FISH WHAT BEARING OUT OF WHAT OIL PAN, TIMING BELT DOES NOT RUN INTO OIL PAN, GET TIMING BELT REFITTED & THEN DO A CYLINDER BALANCE TEST ON EACH CYLINDER, U WILL NEED COMPRESSED AIR FOR THIS TEST & THE SPARK PLUG HOLE TOOL, NOTE USE THIS SITE TO FIND ENGINE TIMING SETUP INFO. GOOD LUCK
SPONSORED LINKS
Monday, July 19th, 2010 AT 1:51 PM
