1999 Saab 9-5
MGONDALES
1999 Saab 9-5 6 cyl 141000 miles
it has check engine light code P0502 and the speedometer not working, warning light,abs and brake are staying on on the dashboard.
Mar 3, 2010 at 1:50 AM
MGONDALES
[quote:ea46b44b59="mgondales"]1999 Saab 9-5 6 cyl 141000 miles
it has check engine light code P0502 and the speedometer not working, warning light,abs and brake are staying on on the dashboard.[/quote:ea46b44b59]
Mar 3, 2010 at 2:16 AM
MGONDALES
is this your answer to my question to buy a manual repair?
Mar 3, 2010 at 2:23 AM
FACTORYJACK
  • 4,159 POSTS
The wheel speed from the wheel speed sensors is an input to the TC/ABS module. From there, it is put on the bus to the main instrument unit(cluster), and the trionic module(engine control module). The abs lights are on correspondingly. The left rear sensor is the one responsible for vehicle speed. The AC voltage, from that sensor would need to be checked at the sensor, as well as resistance of the sensor.
Mar 3, 2010 at 2:00 PM
MNTHNY4
  • 612 POSTS
u need to read abs unit codes ,too for better repair directions ,those codes start with letter C , but anyways u may have a bad abs unit ,get further codes checked using a tech2 scan tool ,with saab software installed ,good luck.
Mar 11, 2010 at 5:45 AM
