Need to replace clutch cable and don't know where to start!
Oct 6, 2010 at 9:59 AM
MNTHNY4
✓Experienced Mechanic
system is hydraulic ,u only can replace hydraulic hose under battery ,fuse box & brake hyd unit ,when u buy the hose it will be complete ,best to have your mechanic do this because u will need to bleed system after ,good luck.
