1999 Saab 9-5
88,000 MILES • 4 CYL • FWD • AUTOMATIC
JLESTRA
Trunk lid will not open with key fob or button on inside of driver door. Will open only with a key. Can you suggest what to do? thanks...jim
Jul 16, 2010 at 5:29 AM
MNTHNY4
  • 612 POSTS
u have a bad trunk lock motor ,get that checked ,or listen if u can hear movement from motor when u hit the key fob trunk button, if u can hear movement then u may need to refit rod that may have came loose ,good luck.
Jul 19, 2010 at 6:24 AM
