1999 Need some suggestions please
80,000 MILES • 4 CYL • FWD • AUTOMATIC
TIMBERWOLF80
Ok so the car most of the time will not start. When it does start it will run for a little while then shut off. I replaced the fuel filter and the fuel getting all the way to the injectors.
Aug 17, 2008 at 12:02 PM
  • 31,937 POSTS
Hi there,
do the rest of the tune up , plugs, leads etc, if you can get a run on an oscilloscope , as this will give you all the ignition voltages and will help pin point any fault, start here.
mark (mhpautos)
Aug 17, 2008 at 3:56 PM
